SOLD 1971 Plymouth Satellite Sebring
Racing4thefinish
5:28 PM
Fort Smith, Arkansas
Feedback: +0 / =0 / -0
Farm Fresh - 1971 Plymouth Satellite Sebring 318 V8, auto trans (904), non power drum brakes, power steering, AM radio, turns on but no antenna and not sure on speaker condition. A/C car and it's all there, i haven't messed with it, I know the vacuum lines will need replaced (dried out) haven't tested or worked on blower motor.
I believe this car to have 25K original miles - was sitting for a long time in eastern OK. Prior to starting this project the car has sat since 1982 (have title and tags from previous owner to show millage back in 82).
Car runs and drives good now - i have personally drove this car well over 500 miles since getting it back on the road. 1 hour road trips to car shows and cruise nights no problem!
new brakes, tires, motor didn't need much, wiring is all good and intact, fuel tank, carb rebuilt, new fuel pump, radiator and water pump were all good, replaced alternator and voltage reg. runs down the highway 70 mph no problem, 180 degrees with 50 psi oil pressure.
all lights works, wipers ect, windows roll up and seal good, oil pressure, coolant temp, and amp gauge all work - i added digital gauges for oil pressure and water temp to get more accuracy to verify engine operating condition.
plug wires and heater hoses that i removed are all date coded, i have the originals. found 3
build sheets under the seats (2 of them for this car, 1 was not) included with the car, data plate still in place on the inner fender.
i swapped out the trans (from a 69 Coronet) but numbers matching 904 trans goes with it - 1st and 2nd gear was slipping.
new drivers side floor pan, passengers side just had pin holes fixed with fiberglass floor was solid enough to use without replacement, 18" Boss wheels new tires 8.5" front 9.5" rear. tires are 255/15/18 front, 365/45/18 rear
what's left to do, needs heater core, dash lights don't work, steering gear box is looser than i would like, needs trunk pan or at least drivers side 1/2, door hinge drivers side could use repair, side marker light lenses are broken, front windshield laminate is separating (typical for 47 years old), speedo bounces around, needs lubricated.
doors, fenders, roof, quarters, frame rails, hood, trunk all solid.
trunk pan is rusted out on left side (see pic) I haven't replaced that yet, i saw a 1/2 dollar size rust hole in the cowl under the dash, rust hole on inner fender from battery acid (1/2 a plam size), but tray is fine(?), small rust hole dime size in corner of trunk gutter, i suspect possible rust under windshield trim.
Clean and clear Arkansas title in hand. $8,750 cash.
Data Plate info:
RH23: Plymouth Belvedere,Satellite High 2 Door Hardtop
C16: 225 145HP 1-1BBL 6 CYL 1971 Newark, DE, USA
E44: 318 cid 2 barrel V8 230hp
D31: A904 3-Speed Auto Trans.
GW3: Bright White Exterior Color
H2B5: Trim - High, Vinyl Bench Seat, Blue
GB7: Dark Blue Poly Int. Door Frames
D06: Build Date: 06
S00710: Order number
CW3: Bright White Top Color
U: USA Specifications
G11: Tinted Glass (all)
H51: Air Conditioning with Heater
M21: Roof drip rail moldings
M25: Wide sill moldings
R11: Radio Solid State AM (2 Watts)
26: 26in Radiator
END: End of Sales Codes
IMG_8223.JPG IMG_8224.JPG IMG_8225.JPG IMG_8226.JPG IMG_8227.JPG IMG_8228 - Copy.JPG IMG_8229 - Copy.JPG IMG_8230.JPG IMG_8231.JPG
