1972 charger
Would you sell just the brake M/C and proportioning valve? Thanks.
Yes I would. Just to be clear on this, it’s from a 72 manual drum brake set up. I’m not sure if this is the same for 71, 73 or 74. Make sure this will work for you.
UPDATED
8.25 rear $75 drum to drum
323 non sure grip 489 case $100
Driver side Door glass $40
¼ stationary glass with all hard wear $35
71 taillights one broken tab but will not affect it. Has a hairline crack in one of the lenses. Wiring needs some work. $75 for the Pair
318 radiator- $75
Non A/C heater box. Two tabs broke can be fixed. $25
Heater cables $25
71-72 charger two Rear valance no cutouts $75 and the real nice one for $100.
73-74 charger rear valance no cutouts need work $25
Non A/C dash frame. $75
Dash frame only for A/C car $50
Rear seat need new covers good core top only free
71-74 charger rear upper panels black real nice $50 pair
71-74 B-body A pillar panels green nice $40pair
4 bow for headliner $40
71-72 charger vapor canister with covers. This is the one in the wheel well. $50 complete
71-72 b-body fuel tank $25
71-72 b-body filler neck with bracket $25
Front drum brake set up complete with manual master & prop valve spindles drums $75.
I have body bolts & miscellaneous clips for 71-4 B-bodies
71-74 B-body door hinges good cores $40
71-72 B-body hood hinges $40
1974 B-body 440 dual snorkel air cleaner real nice shape. $150
71-74 B-Body dash pad cores $40 each
manual steering box $75
73-74 charger grills. Has a crack but nothing missing $25 pair.
71-74 B-body AM radio nice with knobs and bracket. $50
73-74 B-body rear sway bar with only one plate. $50
73-74 B-body shock plates. $40
71-72 B-Body shock plates $40
71-72 charger ¾ vinyl top chrome moldings $40
71-74 B-body lower windshield corner chrome pieces $25 pair
440 water pump housing $25 each
383-400 torker $75.
Upper control arms came off a 72 charger with disk brakes $25 pair.
Auto gage RPM $20
Auto meter sport comp RPM $25
E-body steering wheel $25
71 heater valve nice shape $20
1972 charger SE ONLY drip rail moldings $40 pair
71 charger owners manual used $10
I SOLD ALL THE 72 FENDERS, BUMPERS,DOORS,W/S & DECK LID.
Hi do you have the chrome trim at the top edge of the right front fender just above the bumper, I need a good one.
Thanks,
jld440
update 8/8/13
71-74 B-body parts
8.25 rear drum to drum $50
323 non sure grip 489 case $50
Driver side Door glass $35
318 radiator- $75
Heater cables $25
71-72 charger Rear valance no cutouts $75
73-74 charger rear valance no cutouts need work $20
Dash frame for A/C car $50
Left & right blue upper door panels $25 pair
71-72 b-body filler neck $25
71-74 B-Body dash pad cores $25 each
383-400 torker $75.
Auto gage RPM $20
Big Block 4x4 truck headers $75
71-74 B-body parts
318 radiator- $75
Strato non A/C control.tab in the back broke.Have the tab for easy fix.$25
Heater cables $25
Ash trays (in dash) $10
383-400 torker $75.
Auto gage RPM $20
120mph & 150 mph clusters $100-$350
72 charger left side manual no cable mirror $35
72 charger power disk booster $40
71-72 charger L/S two piece rear upper inside fender brackets $25
71-72 charger R/S two piece rear upper inside fender brackets $25
Set of 5 police wheels with decent tires $200.
10” rear drum brake levers all 4 with hardware $40
71-2 b-body complete 2 speed wiper motor with trans linkage. $100
(I don’t know if 73-74 are the same)
71-4 b-body wiper arms $40 pair
You wouldn't happen to have a passenger side sport mirror off of that charger?
updated 4/7/14
71-74 B-body parts
73-74 B-Body A/C heater control. $25
71-72 B-Body Strato non A/C heater control.Tab in the back broke.I have the tap for easy fix. $25
non A/C heater box. Two tabs broke can be fixed. $25
Heater cables (two) $25
71-74 Charger rear side ash trays. $10 each
71-74 B-Body Non A/C dash frame. $75
71-74 B-Body Dash frame for A/C car $50
71-74 B-Body front speaker core.$10
71 72 Charger Front drums $50 pair
72 charger drum type spindles $50 pair
71 72 charger manual master $25
71 72 charger prop valve drum type $35.
71-74 B-body AM radio nice with knobs and bracket. $75
Cuda AM radio came out of a 1974 $75
440 water pump housing ( 3 left sides and 1 right side) $25 each
383-400 torker $75.
Auto gage RPM $20
Auto meter sport comp RPM $50
SW RPM gauge NOS $100
E-Body inside door lock $10
1972 charger SE ONLY drip rail moldings real nice $100 pair
1972 charger SE ONLY ¼ belt moldings $40 pair
71-72 charger NON SE ¼ belt moldings r/s has a pen ding $40 pair
72 charger left side manual no cable mirror $25
71-72 charger L/S & R/S two piece rear upper inside fender brackets $25 each or $40 pair
Set of 5 police wheels with caps & decent tires $200.
10” rear drum brake levers all 4 with hardware $25
71-2 b-body complete 2 speed wiper motor with trans linkage. $100(I don’t know if 73-74 are the same)
71-72 b-body two speed wiper motor wire harness. Nice $25
71-74 b-body wiper trans $75 I have one set apart for $50
Cragar SS center caps with the washer and screw. (Not the spinner type)
71-74 b-body column parts to covert column shift to floor shift. (Three pieces) $75
71-74 B-Body column shift collor $10
71-74 b-body column base.This is the part that bolt to the floor. $10
Koni rear sway bar new in box. $150
71-74 b-body three spoke horn pad. one Black and one tan and one DODGE center. $25 each
71-72 Charger Blue ¼ ext.one stud on top of the left side broken. $30 pair
73-74 Charger red ¼ ext. good studs.$40 pair
71-72 Charger left side ¼ ext. Green 2 studs broken $5
71-72 Charger right side ¼ ext. Green Mint $25
75-79 Cordoba hood ornament NOS in box .$100
75-79 Cordoba L/S rallye mirror chrome.some pits $25
71-74 Charger left rear chrome outline. Some pits, driver quality $25 I also have two that need to be rechromed for $10 each Cores.
73-74 Charger SE right front filler. This is the piece that is between the fender & bumper.Needs to be painted and the top corner broke off $25obo
1970 RR/Satellite right rear ¼ ext. $25
Ramcharger L/S R/S taillight harness with bulbs mint $50
Ramcharger grill came off a 1989 $50
Ramcharger taillights $50 pair
71-74 B-body 2 speed wiper motor $25
71-74 Charger driver side valance marker light real nice $50
71-74 Charger trunk latch $25
71-74 Charger bumper guards these mount inside the front fenders. $25 pair
727 small block inspection cover $50
NOS Wagner wheel cylinders #FE-54398 $25 pair
71-74 Charger hood latch for cable type (No cable) $40
71-74 B-Body cowl screens $25 pair
71-74 B-Body dash map lights. Tell me what type you need. $10- $25 each
71-74 B-Body green set & black set of sun visors real nice. $50 pair
71-74 Glove box doors green & black (no locks) $20 each
71-74 glove box clear nice $25
71-74 Charger J-pinch moldings White & Green driver quality $10 pair & only one blue $5
71-74 Charger dome light. Just the base $5. With lens $10. Complete with wire $20
72-74 Charger SE pull strap caps $40 set of 4.
71-74 B-Body radio knobs complete with nuts & bracket that holds the radio. $50
71-74 B-Body glove box wire with button $20
71-74 B-Body non retractable rear seat belts. These are the 2 side ones. $20 pair
71-74 B-Body shoulder belt complete with clips/bolts. Black nice color not faded. $50
71-74 B-Body shoulder belt clips $5 each
71-74 B-Body standard dash light switch. $20
71-74 B-Body standard dash wiper switch $20
71-74 B-Body window crank handles $10 each
Is the 71-74 B-body AM radio nice with knobs and bracket $75 still available?
Parts that are SOLD
PARTS THAT ARE SOLD.
71-72 B-Body shock plates SOLD
Upper control arms came off a 72 charger with disk brakes SOLD
E-body steering wheel SOLD
E-Body inside door lock SOLD
323 984 case SOLD
Parts sold
383-400 torker $75.
Updated list
73-4 Charger Driver side Door glass $35
71-72 B-Body Strato non A/C heater control. Tab in the back broke. I have the tap for easy fix. $25
71-4 b-body non A/C heater box. Two tabs broke can be fixed. $25
71-4 b-body Non A/C vent cables (two) $25
71-74 Charger ash trays (in dash) $10
71 72 Charger Front disk spindles $100 pair
71-72 charger drum type spindles with drums $75 pair
71-72 charger manual master $25
71-72 B-body hood hinges good cores $40
Cuda AM radio has cut wire came out of a 1974 $50
440 water pump housing ( 2 left sides and 1 right side) $25 each
Auto gage RPM $20
71 charger owner’s manual used $10
71=74 Charger 150 mph clusters $200
71-74 Charger L/S rear chrome NOS outline $165.
71-74 B-Body green sun visors real nice $50 pair
71-74 B-Body radio knobs complete with nuts & bracket that holds the radio. $30
71-74 B-Body window crank handles $5 each
71-72 Charger fuel tank filler neck $40
I have other parts not listed yet so just ask.Thank you.
Hi, I require 72 drum brake spindles, do you still have them and what would shipping be to Detroit? Thanks Rickp
