SOLD 1972 Plymouth Roadrunner Numbers Matching
Clinteg
8:48 AM
Kansas
Feedback: +0 / =0 / -0
Very solid and original numbers matching ‘72 Roadrunner 340/auto with original build sheet. Basin Blue with blue interior. Power steering and AC, manual 4 wheel drum brakes. It’s been sitting outside in the Oklahoma sun for years so the interior has seen better days. Aesthetically, she doesn’t look great unless you like the patina. BUT, structurally, I have not found any rot in the trunk pan, floor pan, frame rails, torsion bar mounts, etc. New battery, fuel tank, fuel pump, starter, alternator, ignition module, voltage regulator, transmission filter and fluid, rebuilt 850 Thermoquad, etc. Numbers matching drivetrain. Rebuilt engine is believed to below mileage and was rebuilt many years ago (have receipt). Engine doesn’t smoke and fires right up and has a small cam. Body panels and paint are original. Drivers fender was stripped years ago, was sand blasted and warped, and never finished. Same with the top except no warping. Originally a white vinyl top with white transverse stripe car which is a rare combination. Has all the AC components and everything under the hood appears to still be there. This car is about 95% complete and original. The grill is 100% complete and intact. Have an extra set of nice tail light lenses to replace the current ones. The current wheels do not come with car and will come with 14” hurricane wheels that were on it when I bought it. The tires need replaced on those wheels. Has the original spare tire as well. Clear Oklahoma title. Located in Andover, KS. $15,000 OBO.
Build sheet. Still in original condition from when I pulled from the seat and needs to be carefully straightened with steam or some similar method.
Straightened out the build sheet as best I could and taped it. Was like trying to keep a Dead Sea scroll together! But it’s mostly there and is missing 1.5 digits on the VIN. The 8 is missing and the 2 is half there but does show it’s the original build sheet of the car.
Just wanted to add that this is a best offer deal. Shoot me what you got! Worst I can say is no thanks. Would really like to find a good home for this car.
