1972 tail light lamp sockets
jprather
6:56 PM
Tennessee
can you replace the lamp sockets in the tail light housing of a 72 SSP?? or ,, do i have to buy all new tail light housing ??
Dorman Light Bulb Sockets 85860 - $5 Autozone
Carefully. That old stuff can be brittle, or very soft, and break easily. You don't want wedge anything between the socket and the housing or you could crack the housing. Don't use any chemicals or they may soften and deteriorate the housing. I would try dish soap around the interface. let it set a bit, then gently wiggle the socket as you pull. Just watch the housing for any cracking.
You could also take the entire housing out, remove the lens, and use a pliers to pinch or bend the socket tangs. That might make getting it out easier. You still need to get the new one in. Soap.
will give it try !! i will pull the whole thing out,, gotta take the bumper off anyway just to get to the bulbs !
