- 9:10 AM
- Jul 31, 2011
- Western Colorado High Desert
1973 Chevy Corvette. 454 4-spd T-Top.
Manual brakes.
Manual steering converted to power steering.
Am/Fm radio.
Leather seats
This car is a nice driver. Believe it has original paint. Think the interior is original except the front carpet and steering wheel. Motor does not have the vin but is a 73 casting. Odometer says 91280 and is probably original miles. Lots of patina inside and out.
Car has been gone through and things repaired or replaced as needed to make it road worthy. This car is not restored.
Suspension: New upper and lower control arm bushings, shocks, trailing arm bushings, rear wheel bearings, rear left spring and end links,
Steering was manual but has new power assist added.
Brakes: New pads, calipers and rotors.
Motor: New cam and lifters, radiator, water pump, carb, alternator, belts, battery, fresh tune up and service. Other than that I don't really know anything about the motor other than it is a 73 454.
New exhaust and manifolds,
Body is in good condition. Paint is worn and has its fair share of chips, scratches, scuffs and stains.
Found cracks in the front pass fender and corner of hood. Don't see any signs of a wreck.
Interior. Is a bit worn but is clean and in good original condition. Front carpet is new. Radio doesn't work. All the gauges works except the tach due to distributor being changed. Oil gauge does not work but motor has good oil pressure. 60-75 psi.
All the lights work except the back up lights.
Has new heater core and heat works great.
Car runs and drives really nice. Motor runs strong for a 73 454. Transmission shifts nice and smooth but is a bit noisy in 1st -3rd and quiet in 4th .
Has newer tires with most of the tread.
14500.00
Manual brakes.
Am/Fm radio.
Leather seats
14500.00
