1973 Dodge Charger SE Restoration
Scauzone
4:54 PM
Motor City
Finally making some head way again on a 1973 Dodge Charger SE. 2BBL - 400 - Torqueflite.
I need a fair amount of parts to begin reassembly and am wondering if someone can point me in the right direction to buy these parts.
Engine to transmission bolts.
Flex plate to crank bolts.
All engine accessory bolts.
Front Fender Bolts.
Hood Bolts.
Hinge Bolts.
Fender Clip Nuts.
I need bolts...and nuts. If someone knows the sizes, that is fine too.
Ok, I found the Flex Plate bolts for .76 cents each. 7/16 - 20 x .500". If anyone has a better suggestion let me know. Still need all of the other ones.
Body bolts didn't change much.
If you have a "u-pull" yard nearby, look for 80's trucks, M bodies (5th Ave, etc), even G bodies (Daytona) and K cars.
Megaparts.com and partsmix.com also have bolts. Pricey but factory correct. Check on ebay as well. There are plenty of sources.
Thank you.
L-Body and AA Body in the garage. I have plenty of spare bolts for both, but I'm looking to use new bolts. I appreciate the heads up though.
Thanks. I'm actually working with partsmix right now. Seem to be a good source, and as you stated, factory correct which is what I'd like to stick with.
we buy from AVECO
for body and fender bolts.
Thank you.
