1973 plymouth roadrunner 400 big block motor mount inserts
midnightrider1818
2:36 AM
Mid West
Hey guys looking for a set of spool type motor mounts for a big block 73. I have found the anchor rubber mounts but everyone says there for small block. I was really wanting polyurethane mounts. All I need is the inserts as I have the brackets and don't wanna spend a 165 dollars for a set off mancini or something. Any suggestions
The same thing I ordered w/o Trans mount. The big p.i.t.a. is getting the old rubber out of the housing. I used a torch and burned most of it out. Smelled like I was doing a burnout in the driveway. Smoke included! While it is hot and gooey, use something disposable to scrape out the remainder. The cleaner you get it the better the new one fits! Takes a little time and patience.
