FOR SALE 1973 roadrunner
William Baldwin
New Member
8:30 AM
Florida
Feedback: +0 / =0 / -0
1973 Plymouth Road Runner. Car is originally a 318 car, although the current engine is a 400 that has been stroked to 451, 3.750” stroke/ 6.760” rod. This was purchased from “440source.com”. The engine was put together by Fun King Motorcycle’s and Customs in Holly Hill Florida. Has an “RV” cam. This car runs but could use a tune. The carb is an edlebrock carb, manual choke, although the jetting seems to be a little off. This car sounds amazing and has an old school sound with a custom 3” full exhaust with flow master 40 mufflers. This is a true dual exhaust, straight off the headers that have been ceramic coated white.
Car looks good both in and out. Has a new vintage AC/ Heat that was custom put in. New power steering pump, new AC condenser as well. Will keep you cold and warm! Replacement metal has been put in on the floors, which was replaced 4 years ago. Interior was custom and replaced to match original interior. Sound deadening/ Heat displacement padding has been put in. New carpet throughout car. Trunk has no rust.
Almost all Rubber has been replaced, as well as body mounts. The only thing not replaced is the dash pad, the body, and some of the glass. Larger than stock sway bars have been put in, to manage the body roll. Rims and tires are modern 17x8’s and 17x9’s with modern rubber, purchased by Summit.
New rear axle with strange axles and gears. Disc brake upgrades on the car with hawk blue pads in the box. New windshield wiper motor. All new wiring front to back, put in by Cruising Gold in Melbourne Florida. We put a full custom painless wiring wiring harness with fuses. New lights front and rear.
Has a custom sound system in car, in stock locations and head unit is hidden in glove box. The gauges have been replaced with more modern electronic gauges.
With a new tune, the car can be used as a daily driver! Has won several shows and always draws a crowd.
Asking 16000 obo, located in florida
