FOR SALE 1974 .030 over 440 short block
Iroc78
8:15 AM
MI
Feedback: +1 / =0 / -0
1974 440 Mopar short block. Rebuilt .030 over with less than 500 miles on it. Previous owner said it was running at 220-230 degrees and couldn't get it run any cooler so after swapping heads with no change he got fed up and pulled it and swapped in a modern engine. I pulled the heads and saw some very small valve marks on #4 and 6 pistons that you can see if you look closely in the last picture that you can barely catch your fingernail on. I don't know the specs on the cam but he described it as mild. Aluminum water pump housing and water neck. Cylinders look great and most of the carbon just wiped right off of the pistons. I would give it a thorough before I ran it but I suspect there's not a whole lot if anything wrong with it. $1250.00. Pickup in SW Michigan, 49079. Please PM me if interested. Thanks,
