I would like some more info on the 2" drop spindles for a 1969 Charger. I read that they are patterned off of the 73 and up B body spindles, if so I imagine they will except the 72 calipers? The reason I'm asking is because I'm trying to put my car on the road by spring and have to swap out the calipers from the 73 style to the 72 because of clearance issues (I believe someone swapped it to the late B body spindles). I'm hoping to buy your spindles somewhere down the road "hopefully before spring" and want to make sure the 72 calipers will fit so I'm not buying calipers again plus I was curious if it matters which side your spindles are mounted on (mine are on the back do to the sway bar mounts). Thanks
