WTB 2 groove crank pulley
muscle72
6:56 PM
usa
Feedback: 3 / 0 / 0
Lookin for a good used 2 groove crank pulley for a big block mopar it,one off a small block it if works.
For better luck, you'll need to be more specific. Diameter and depth are necessary. There are a LOT of different pulleys that were made. Multiple years, Poly, LA, B and RB A/C or not, etc.
Need one for a 440 426 413 rb 383 400 b. They all used the same when came to depth and diameter.As along the 2 groove crank pulley came off a big block
Keep thinking that. I was trying to help you.
I have these off a 440.
I might have one at home. If you don't find oneby Sat., I can look then. I have a spackle bucket full off Mopar pulleys; there is a good chace I will have one.
Oh ok yah l do l could wait Intel then
I didn’t find a two groove but I did find a four groove that looks like it was pressed together!!! I’m wondering out loud if anybody knows if these guys can be heated and “popped apart “ or are they spot welded together??? If you look closely, you can see a parting line between the two!
Thats an A/C pulley, they are spot welded together.... FWIW Kern Dog was 100% correct but the O/P can believe what ever makes himself happy...
