2 speed wiper motor steel inserts 71 charger
velrob
9:07 PM
toronto
anyone know if the steel inserts that go inside the grommets are are repo'd? for the 2 speed wiper motor
mine are all messed
thanks
Not sure if they're reproduced or not, but you could either pull them out of another wiper motor (I think they're all the same) OR find some steel tubing (maybe larger rolled pins) and cut some.
theres a washer attached to the back of the steel pipe
ill see if i can find another wiper motor
thanks
Try Passion4Mopar. I'm fairly certain they sent new ones with my motor they did. Aren't they brass?
mine look like steel
ill email passion4mopar to see
thanks
lol i saw this posting on amazon.ca:
BySCQUEon January 7, 2014 - Published on Amazon.com
Verified Purchase
Worked fine on a restoration project (1972 Dodge Charger) Did have to drill it out a bit for the studs to fit.
awesome ill order those even comes with the rubber part, sweet
Hello Rob, I have one from a 2 speed wiper motor (see pic below). It's brass and I have the insert as well.
