RENNUR96
Need 4bbl intake manifold for 1968 273
Thanks for reply add a little high
www.forabodiesonly.com
It's the normal small block bolt size and angle. The D4B fit's the 64 and 65 heads and has the small bolt holes and the odd angle.Is that the angled bolt pattern?
Yea my thoughts too... But it is an option if you are desperate enough.Thanks for reply add a little high
Just want to make sure I get proper intake for this engine, I was recently taken for a new intake ,carb & cam let guy work on car at another guys garage man called said to come get car he skipped out not to be seen. Left with top end apart no keys balance part were said to be in trunk had keys made suprise no top end parts.Yea my thoughts too... But it is an option if you are desperate enough.
