FOUND 3:23 gear set for 742 case
dan juhasz
8:45 PM
Whiting NJ
Feedback: +24 / =0 / -0
preferably I’d like a known good oe Mopar 3:23 gear set for a 742 case, coarse spline pinion. I attached a picture of ring gear that has a Mopar part number on it. It had three chipped teeth. This gear set uses the pinion that is straight, does not use a crush collar instead it uses shims to set pinion bearing pre load.
Dan
