Dickey
I've noticed a peculiar behavior with the Polara's carburetor since I've had it and I'm curious if this is a known issue in Mopar circles. I tried searching but I didn't find exactly what I was hunting. My issue seems to be that my accelerator pump is leaking. It still works to squirt fuel on quick throttle events, but when the car sits and idles it runs insanely rich and with the engine off, and the electric fuel pump regulated down to 1psi gasoline seeps around the lower gaskets and the throttle shaft.
I had noticed this earlier with the original Stromberg to the engine that I rebuilt shortly after I got the car. The accel piston would bind so I reused the old one to get by. I chalked it up to me doing something incorrectly and purchased a rebuilt carburetor from an ebay seller who had 100% feedback on his rebuilt carburetors. As far as I can tell, opening the throttle lowers the accelerator pump linkage and allows an internal spring to push the piston down to squirt fuel into the carb throat. It appears also that this linkage also regulates how far down the piston is allowed to move during part throttle.
When I rebuilt my carburetor, the new piston would bind in the cylinder and the car had zero accelerator pump action. The replacement carburetor did this same thing. I gave it a hundred miles to clear up but it did not. I pulled the top plate off of the carburetor and lightly sanded the sides of the piston so that it would move easier within the bore. This worked great for the last 1000 miles or so but I noticed this evening that it is idling rich and seeping fuel again. I also pulled the breather and saw that the linkage no longer pulls the piston as far up as it use to. It is short about an 1/8th inch or so.
Is this some manner of common failure that is easily remedied or do I just have uncanny luck in what not to own for Stromberg WW carburetors?
