of a 318 or a 383,
I'd do the 383, a few bolt on it'll perform great
yeah you can build the 318 LA, I've done several they respond well to mods
I beat many a BB back in the day with a temp mild built
(68) 318 in my 68 Charger R/T (w/5.13:1 gears, 28" N50/15 tires)
while building another 440 or 513 stroker, because the OE 440s had a tendency
to spin rod bearings when pushed hard, past like 5,800rpm on stock rods
but the 383
will have more grunt/torque than any small block stock stroke
unless you do a stroker, might as well build a BBM, B/RB for that price
& they made millions of 383s
(67 closed chamber heads can be decent too, if done properly, especially on a lower compression combo)
the 383 HP in 68-70 are great engine swaps, lots of them out there
383s many, many of them, 383s came in (270?) common 290-335hp ranges,
the 2 bbl 383 or cars with A/C has less HP ratings
the 68-70 RR/Super-Bee or the 383 Magnum all had a lil' more cam
than a normal truck or (A) C-body motors, w/same 906 heads
383ci 335hp RR engines (Super-bee too) had a hotter stock cam,
like 268*/0.468" gvl, give or take, it's the same exact cam as the 440/6bbl is,
& you can always do a camshaft replacement too
(don't go over like 0.510"-ish gvl, or you need to cut down the valve-guides for lift clearances
284*/0.484" is a great street cam for a mild 383, idle well & decent vacuum, good response)
put a set of 1-3/4" headers, 2-1/2" free flowing exhaust,
an Edelbrock Performer RPM 4bbl square bore dual plane intake,
"best intake for the street hands down on any B/RB engine, even at 550hp levels"
buy a decent 4bbl (Holley IMHFO, 7310 VS is near perfect for street & mild 383, w/727)
& a gauze style air cleaner (like a K&N)
a lil' hotter spark/ignition & coil & good low ohm resistance plug wires, to burn the extra fuel
& call it good, maybe a converter & gears
(an OE RR has an 11" converter is a lil' loser than most cars converters,
unless it was a Super Bee 383/335hp)
& install way better gears than what it has now, 3.23:1 at a min.
(lots of them out there cheap-er)
if you go with a taller tire, like a 275/60/16 28" tall
then maybe go to a 3.73:1 or 3.90:1, (needs a 3.55:1 at a min.)
a 383 will like the RPM & help keep in the power band range
a 360 Magnum isn't a bad option either (a lot of them out there)
but a lot of differences in a LA style SBM than a Magnum
most stuff doesn't interchange, some does
so if you go that route do your due diligence/research
good luck
