340-360 heads on a 318 poly?
Moparaddict
1:06 AM
Lake Elsinore
Just wanna see if you guys can help me out here: I'm trying to see if i can fit a pair of 360 or 340 heads on a 318 poly. the poly is a 1966 318 out of a belvedere II.Still looking for Some heads so if you hear Anything Let me know thanks
318 poly is an"A" series engine. A regular 318, 340 & 360 are "LA" series blocks. Won't work due to the blocks are toally different.
i think the bore spacing for the early A and LA are the same. head bolt pattern may be the same (?). i doubt the cooling passages will line up and a poly cam has the intake/exhaust lobes in a different position. tappet angles may be different also.
See above link I posted to the other thread the OE thread starter, started.
Correct
Correct
Correct, correct, the valve arrangement is I,E, I, E, I, E, ETC...
Incorrect, there the same.
