Texas charger 73
i have a 73 charger and im buildng a budget 360 for it. my goal is at least 350 hp. here is what i got with the motor, stock block bored .40,stock crank,rods. pistons are sealed power(ch 1.576), cam is a Erson TQ20T(gonna get replaced), stock 596 smog heads with aftermarket springs,retainers,dampners and locks, LD4B intake(getting replaced as well),
who has had success with these heads. i hear the cc is between 70-72, gonna kill compression. i have been told to get a set of J or X heads,but i cant find any cheap enough so this what i got... i will be running headers,either a comp 260 or 280 cam,edlebrock performer intake,unless you have a better suggestion... im all ears guys...i was also told to add a windage tray,but my main cap bolts are bot set up for windage tray. gonna br running a thermoquad 850 cfm as well... should i replace the pistons and run the 596's or keep searching for the other heads? also was suggested to run magnum heads with oilable lifter and pushrods and the magnum rockers also going from 1.5 to 1.6?
