360 oil pan gasket
Micah Pohlman
8:48 AM
Minnesota
My 78 Sport Fury is getting worse in the leak department so it's time for a few new gaskets. It's been awhile sense I looked that close at this aspect but can the oil pane be completely removed or will only just be able to be dropped down a little ways? Thanks for the help.
-Micah
In my 77 cordoba I've replaced the gasket and pan a couple times. I didn't have to remove anything, although I have a 440 in it so that could be why I didn't need to remove the cross link. I fought oil pan leaks for a long time and I finally ended the leaks with a new oil pan. The original pan was a bit warped from the constant tightening/on/off ect.
