Banzaiii67
I believe you need to use a multi layer head gsk such as Cometic with an alum head. The Stealth heads are usable OOTB if you don't go over .510 lift. More lift I would change the locks and keepers. Also some pocket clean up and blending will help the flow somewhat.
Well after reading that link above on head gaskets, it looks as if a lot of guys are using steel shim head gaskets with copper coat, or hi temp alum paint, on alum heads and getting away with it. Makes them look more attractive to me, as I like the .020 steel shim gasket. Never had any problem with them on an iron head. They are about $25 a pair. We used the 1135 Mr Gsk steel shim gasket on a 383, and no probs. C/R of 13 to 1.
From the small bit of research I've seen on the web, it appears you definitely can use a .027 Cometic MLS Gasket. A guy on moparts has one on his Charger. A bit pricey at $165. Of course they are custom built to your bore and you can reuse them. I don't know if I have enough confidence in running a prepped steel shim gasket on a aluminum head for .007
