383 HP valve sizes
Richie
7:27 PM
Kelowna BC Canada
Hi everybody:
I have a really good 1968 383 but it's a dished piston engine. To make it an HP equivalent I'll need flat tops and do I need to change valve sizes and to what? It has 906 heads. It was rebuilt about 1500 miles ago but it will all be taken apart again because it's been sitting so long after I got it and I can't have it with the low comp. anyway.
Hi everybody:
R413 is correct. To convert to”HP” you’d install flat top pistons and a slightly larger cam….done! Oh, and maybe a different carburetor. Now it’s an HP motor
You have 2 piston options:
1) Silvolite 1267, Piston Compression Height 1.824", Piston Volume +10cc 4v, Flat Top Piston
2) Kieth Black 243, Piston Compression Height 1.840" (piston ~+0.018" above deck), Piston Volume +6cc 2v, Flat Top Piston
Nevermind, my mistake...
Whatever pistons you use....weigh them on a gram scale and compare to your originals. If they vary more than 20 grams,a rebalance will be needed i.m.o. .
If heavier.....you can take that amount off of the small ends of your rods to compensate. A machine shop can do that for you instead of a more expensive total balance job [at like $300 or more] . Good luck.
The OP has a 383.
Is it standard bore and has the original dished piston? Was it rerung? There may be more wear you can't see with the naked eye. I've seen cylinders that looked great but were completely shot when you measure it. Some cylinders can be straightened back out with a fixed hone. Do some measuring before you throw pistons at it.
The shop will find that out. I trust them I've known the family almost all my life.
