383 motor mounts for a 74 charger
dodge1972
8:05 AM
Aurora, CO
Planning to install a 69 383 to replace the 400 in a 74 charger. Noted the motor mounts are differ. Any suggestions or recommendations. Thanks
Why would the engine mounts be different? They are both B-Blocks. Other than the styles. You should be able to use your 400 engine mounts on the 383 no problem.
Yes use your 400 brackets on the 383. Nobody carries the BB brackets just the SB ones but you can buy the rubber inserts in both rubber and poly.
Were talking 73-up spool mounts.
engine mounts changes on this case due the car not the engine. So since you already have a 400 with its mounts, just need to use the existant mounts the same for the 383.
you can replace the bushings. Rubbers should be available at any parts shop
Rockauto:
https://www.rockauto.com/es/catalog....6l+400cid+v8,1440890,engine,motor+mount,5552
maybe getting same PN can get it from your local parts shop, saving on shipping
Weird is when you search for 440 rockauto only offers poly energy suspension... being the same!!!!
a pair on ebay
https://www.ebay.com/itm/Pair-Spool...631437?hash=item444376bdcd:g:NBIAAOSwiHFdVb5W
