maddart
Hi
Just a little history
I had this engine built by a pro stock engine builder. Builder is not very helpful and I can’t count on support.
This build was a slightly more aggressive build than a stock 1967 383.
The following combination of parts were used in the build:
Block machined Bore & torque plate .040 over, Crank clean/check and balance, Closed chamber heads
mill decked with 3 angle valve job. Valve size was increased to 2.14” intake/1.74” exhaust
Ferrea stainless valves were used
KB hypertech 162 pistons with sealed power E233 moly ring set .Stock rods with ARP 145-6002 bolts
Sealed power cam KC661 (Same as Speed pro CS661?) Specs for speed pro= Duration 292 intake/309 exhaust, duration@ .050 214intake/225 exhaust, lift .449 intake/.464 exhaust Lobe C/L is 115.
Sealed power valve springs VS-865 Closed press 109/ open press 323
Comp cam 7948 5/16” pushrods (Listed for ford BB) Mopars not available at the time??
Headers with stock intake and a 750 holley 4160. 4 speed 3:23 gears. 3800# car
I have been trying to get timing down. (Builder said to set at 10 degrees BTDC-This didn’t work to well) With dial back timing light the car seems to run better at the following:
(Current settings)
700RPM 18degrees BTDC
1500RPM 30degrees BTDC
2000RPM 43.5degrees BTDC/60 degrees with vac connected
3000RPM 43.5degrees BTDC
When timed at 12-15 degrees BTDC@ idle the motor runs extremely hot. There is a very noticeable difference in temp under hood when timing. (Also smell un burnt fuel from exhaust)
I just don’t want to damage the motor. Motor seems to want even more advance than the current settings.
Any suggestions on how to improve the timing/vaccum/engine combination would be greatly appreciated
Adjusting carb yields a vacuum of no more than 16 inchs.
I am hoping to change intake to a weiand 8008 dual plane in the next couple of weeks.
(Current settings)
