smithchargers
Nice fully functional 4 speed trans, 10.5 bellhousing, inspection cover, shifter mechanism, and linkage. This set up came out of a 72 big block charger that received a viper v10 and 6 speed. This trans needs nothing. It shifted great when removed. The flywheel, clutch set up, and shifter handle were used on another project so those are not included. The main case has casting 95639 on it which is early B body but it has the 71-74 b body and E body style tailshaft on it with 2 mounting pads. This trans was obviously gone through and built this way. Just add flywheel, clutch, and shifter handle and you have a set up that needs nothing. $700
