4 wheel disc conversion on a 71 roadrunner question
jonny0666
4:31 AM
S.I., N.Y.
I'm doing a Right Stuff disc conversion on my 71. Is there any special set up needed for the distribution valve to run 4 wheel disc? Thanks in advance for the help.
You don't need the disc prop valve to run disc/disc. I'd find a drum block,they work best with disc/disc swaps
I would add an adjustable proportioning valve in the line to the rear brakes and adjust on wet road. You want the front to just lock up before the rear.
