FOR SALE 400/512 stroker
dyolf82
7:49 PM
Lexington Ky
Kicking around the idea of selling my engine... it’s a 400/512 stroker. The engine has never been run and I’ve got receipts to everything purchased. It has Edelbrock top kit (heads- not ported, intake and cam). The rotating parts are from 440 source including pulleys, oil pan etc. Manton pushrods... The carb is a professionally built carb 1000cfm. I will throw in a freshly rebuilt 727 with shift kit etc. The only used parts on this engine are the block and rocker arms ( crane iron ductile) I’m looking for at least $7,000... I’m located in Lexington ky. Inbox me with any questions
Maybe include which heads & intake, cam specs & compression ratio. What internals on the 727?
Has the motor been dynoed?
No it’s not been dynoed yet...
It’s the Edelbrock top end kit... so Edelbrock rpm heads and intake but I’ll hunt down specs and post. I also paid for the extra lightweight crank from 440 source.
RPM Power Package Top End Kit
  • 1968-1979 Big Block Chrysler 383ci
  • 421HP; 417TQ
    Includes:
  • Intake Manifold/Bolt Kit 1500-6500 RPM Range
  • Cylinder Head/Bolt Kit
  • Valve Size: 2.14"/1.81"
  • Port Volume: 210cc/70cc
  • 84cc Combustion Chambers
  • Max Lift: .600"
  • Camshaft/Lifters
  • Lift: .480''/.495''
  • Duration @ .050: 238°/246°
  • Advertised Duration: 300°/308°
  • 1500-6500 RPM Range
  • Timing Chain Set
  • Head Gasket Set
Headman hedders 78030
Transmission rebuilt: Dodge A727 Transmission Deluxe Overhaul Rebuild Kit TF8 71-On Level 2 Kit
MOPAR 383 HiRev Electronic Ignition Kit Resto Stock Look Plymouth Dodge Chrysler
B&M Tork Master Torque Converter Chrysler Torqueflite 727 2400 Stall
HOLLEY, QFT 1050 HP DOUBLE PUMPER, ALL ALUMINUM, STREET, STRIP, HEAVY-DUTY BASE
440 source stroker kit 400/512, extra lightweight crank... pulleys from 440source
Specs for the stroker kit... I bought the upgrade for everything and have receipts to show proof.
