- 1:11 AM
- Oct 16, 2014
- Salisbury, Vermont
I have a Holley dual feed 750 CFM elec choke carb. I was reading an article which stated the 4160 carbs have side hung floats and the 4150's have center hung floats. My carb is a 3310-3 list # and has center hung floats in both bowls. Which is it? 4160 or 4150? To further confuse the issue it has a Elkton 12R-4470B base plate. Primary has a metering block, secondary a metering plate.
I was under the impression that the 4150 has two metering BLOCKS. Am I wrong? Or am I missing something? Like this carb is a mashup? Or what?
EDIT:::: After reading more of the article I must have a 4150 carb.
