426 hemi ignition coils
Beekeeper
It’s a disease without a cure!
10:00 PM
Rogersville,TN.
So I need to pick up a coil for my hemi I’m running the factory dual point prestolite distributor
with the ballast resistor. What brand coil do you guys recommend? I was thinking
about using the standard brand coil just wanted to see what others suggested.
Oh and it’s a street driven car and has right at 11:1 compression and using autolite AR 53 plugs for now.
Thanks
Using an oem mopar coil on mine. Same dual points ignition system
Thanks guys! So how about plug gap? I know there will different gaps but just wondering what others are gapping to.
Thanks again
I’ve been using .017” but like to check with a dwell meter once up and running.
I like to use a the trusty chrome Accel coil or if you want a stock look, I use the MSD blaster coil.
It is red but I paint it black to look like a stock coil.
@Jerry Hall A painted MSD Blaster coil is what I used on your red 67 GTX
It's been changed, as well as the distributor.
