440 6 pack Coronet
steersdad
4:48 AM
Connecticut
Feedback: +0 / =0 / -0
PRICE REDUCED FOR QUICK SALE. $8,995.00 FIRM.
If you are a fan of 60's Mopar Muscle cars, this car is for you. My restomod 67 Coronet 440-6 pack. I am so busy with work, I have no time to spend on my Coronet.
It is not an original car. No 6 packs in 1967. Not until 69.
The body is in very good shape. It has been sanded and primed with high build primer. Now needs to be sanded so you can re-paint to b-5 blue (my favorite color). The price includes 2 gallons B-5 blue base coat, 2 gallons clear coat. Most chrome and trim is off the car to make the job easier. You will need to D/A or block sand it and shoot on the paint.
Black vinyl top is excellent. Interior is almost perfect, dash pad has one crack. Carpets & headliner are in A-1 shape, as are seats.
The engine is a 67 440 motor, with aftermarket cam (hydraulic), 906 heads, Edelbcock aluminum 6pack intake, carbs, air cleaner. Mopar Performance electronic ignition with chrome box. It has a belt driven fan and an electric fan on an aluminum radiator
Trans is big block 727 with 10" converter. It will need either a new neutral safety switch, or the wire to the solenoid is disconnected. It will start in gear. It has a column shifter.
Rear is 8 3/4 with 3.23 sure grip, but I also have a spare 489 case with 3.91's (available for an additional $500.00). Has a Mopar Performance pinion snubber.
Recently upgraded to front Mopar disc brakes and Musclecar Ceramic rear brakes (0 miles) included new spindles. I have not yet installed the new master cylinder or proportioning valve. Brakes work with the old master, but you need to pump them.
New Mopar Performance leaf springs in rear. Some time ago 440/hemi torsion bars and front sway bar were installed. (new end links with poly bushings installed). New bolt on 6 pack scoop not yet on the car.
Newly installed (0 miles) rebuilt power steering box.
17X 8 wheels with ZR rated 245/45/17 Goodyears.
Underside needs detailing. No rust, just gunk and lots of rubber from burnouts.
Very nice, solid, sharp car.
I have a clear, transferable Mass title.
Car was originally a 318 Coronet 440. Not a Roadrunner, GTX, Super Bee, or a Charger or Coronet RT
Photos on CL: http://nwct.craigslist.org/cto/3182460665.html
A nice car, I just am physically unable to continue playing with it.
Trade???
Anybody have late model Jeep Liberty, Dodge Nitro, or similar 4x4 SUV for trade? I'll add cash as required.
DS
interested in coronet, have a late model jeep liberty would be willing to work a deal with you.... pm me . I live in western mass......
six pack setup is sold.
I have sold the six pack setup. Car is now being sold with 4 barrel intake, OR rolling with no engine/trans.
Spare 3.91 rear is sold.
Make offer!
Car is for sale on ebay now
prices
The car minus engine & trans is $4,500.00.
On your wheels and tires, $4,000.00.
6 pack is sold.
3.91 rear is sold.
67 440 motor is still avaialble. Runs well, sounds mean.
727 with 10" converter still avaiable. Car is still intact, complete, and running as of 9/11/12.
sold
only the engine and trans available now
67 440 engine with 727 auto and 10" converter.
1967 Mopar 440 (C-engine code) with 4 barrel. 68 906 heads. Mopar Performance Electronic ignition, Mopar Performance valve covers, aftermarket hydraulic cam (Belive it to be Mopar Performance 284 degree, .484 cam). Taylor wires. New plugs and oil change. New fuel pump and fuel lines.
Power steering pump, alternator, pulleys and brackets not included. Runs great, still in car.
If you are interested you may come to make a compression test, leakdown, AF/O2 sensor, or any other test you'd like. . Runs well, 70 psi oil pressure.
hear/see it on youtube:. 1 leaky Valve cover gasket . six pack seen in video is NOT included. Price includes 4 barrel intake and carb. Don't want 4 barrel intake?, will deduct $350.00 and sell without it.
http://www.youtube.com/watch?v=eupAsoFkdaI&feature=youtu.be
will crate to ship. better if you pick it up. 100 miles north of NYC.
