440 .60 over?
drobertson
12:38 AM
Wyoming
I got a 440 awhile ago, and upon cleaning one of the pistons, it was stamped ".40". The block had a little rust, and I want to know whether or not it's safe to go .60 over. The block is a 1974 Casting. Do I need a different block or should I just sonic check 'er and go from there?
Sonic test it and see. Chances are it's fine assuming the bores clean up at .060. If you plan to go bigger, personally I prefer to find a virgin bore to start with, but again - sonic test it.
2nd that.....spending the money on sonic testing is well worth it. It also depends on how much power you are wanting to make with it. If it's a little bit thin, building a mild engine will probably be ok but making a 600 hp beast may not be ok.
Another vote for sonic checking. Thin spots may not be an issue depending on which axis they are located.
Right....it's usually not so much as having the whole cylinder thin but core shift is usually the main problem. I've found blocks that were plenty thick 3/4's the way around and be thin on the thrust side....that you don't want.
Thanks all, the bores are pretty straight, and have no ridge at the top. The engine was rebuilt, then ran for 5k miles, and then yanked to sit in a field for a long time. I might just be able to hone it, and keep it at .40 over. I will be sending the block to a machine shop soon to have in cleaned, sonic checked, new cam bearings installed, and honed. Maybe bored if necessary. Goal for this engine is 450-550 horsepower. The machine shop nearby has an engine dyno, and I'll have it tested after assembly. I might have them assemble the bottom end, then I'll install an edelbrock top end kit and a tci or b&m transmission capable of the torque output.
