WTB 440 Bellhousing -- For run stand
demon34071
New Member
5:22 PM
Pittsburgh, PA area
Feedback: +0 / =0 / -0
WANTED: Looking a cheap 440 bellhousing in order to bolt my 440 to a run stand. I'm running an auto in my GTX but want to run stand my engine prior to putting it back in. Turns out I brain farted and forgot I need a bellhousing to actually bolt it up and mount the starter.
Looking for something cheap since I'll have no need for it afterwards. Would need shipped to McKees Rocks, PA 15136 or be close to Pittsburgh so I can pick up.
Thanks!
You need a flywheel too for the bell housing to work, and it needs to be either balanced or unbalanced depending if the motor is internal balanced (forged crank) or external balanced (cast crank).
https://www.ebay.com/itm/2868170637...m_qtmOJyFiQ8y8YuF9EemHRFwzoEgTRhoCbeUQAvD_BwE
Already have the flywheel. The run stand I’m borrowing from a buddy uses the bellhousing trans bolt holes to mount to the stand, so a 727 housing won’t work either.
