TheGodfather
Backfiring engine
YES......connect the Vac advance. This small rubber tube runs from the distributor to the carb. It will automatically advance the timing as you increase RPM. Set your initial timing at 25 degrees at 2000 rpm. I'm not certain that will fix your backfiring issue tho... The new MSD wires are a great choice and should eliminate bad wires as an issue as long as you've got the right firing order in place. Bending the plug wire boots going to the plugs shouldn't afftect anything. You certainly don't want them touching the headers. If the old plug wires were burning on the headers; that could've caused the problems you have described. Let us know what's going on after these things are completed.
i use heady heads with kb 237 pistons on an 73 engine stock cam used(anybody here runs this setup????)....and about the vac advace its not connected from the distributorr??should i hook it up??
i put in a new set of msd street wires...but me mech had bend 2 sparkplug ports so it wounldt touch the headers...could this cause it?
