440 hp id
jfkrz
10:52 AM
akron ny
Was the placement of the HP stamp on a 440 ID pad always placed at the bottom right side of the pad. Would it ever have been placed after the 440 stamp on the top line. Does an upside down A mean its an HP engine. Thanks
I'm curious as well. Post a good picture of your engine ID stamping pad.
Mine and most I've seen have the "HP" only on the lower-right. As for the upside-down A, I read somewhere that it's most likely a stamping error. Are you sure it's an upside-down "A", and not a "V" with a stray center mark? This thread has a good explanation, see Post#6 from 71383bee:
http://www.moparchat.com/forums/showthread.php?t=51644
Side-note: Mine says "HPA" in the lower-right, the "A" is suppose to mean .020 over-bore, possibly because the original standard boring wasn't uniform across all cylinders and within specs, so they re-did it. Dunno for sure.
http://www.forbbodiesonly.com/moparforum/archive/index.php/t-7443.html
For future reference here is an excellent page with lots of 440 info, stamping codes:
http://www.moparts.org/Tech/Archive/motor/36.html
Ill try to post a picture of the id pad. Thanks for the help
I don't think you linked the right picture. Check it. :)
Also throw up your engine casting number on the left side of the block to verify.
