440 leaking
ukieone
5:43 AM
missouri
do all of the header bolts go thru water jackets? how should I have prepped them?
Same here and have used Teflon paste with good results too.
thanks all,should of thought of that when it was dry.
Thats one thing about Permatex #2, you can apply it to the threads and insert it whether it's wet or not. Preferably dry would be better. Blow it out with a air hose. Spray some parts cleaner in each hole to really dry.
Good luck
Good luck
Yeah, I use Permatex too, same reason
