- 3:04 AM
- Jan 14, 2009
- Shoreline, Washington
Fact is, The HD rod (2951906, commonly referred to as the “six-pack” rod) was first introduced in ’70 and used through ’75 on all steel crank HP 440 applications including some truck and motor homes. Only the ’70-71(a few ’72) six barrel/six-pack HP motors running the heavier high-compression pistons (10.5-10.2 CR) required external balancing. All other lower compression piston, HD rod, and steel crank 440s were internally balanced.i don't think so.
