MoparHonda
I have a '70 Plymouth 440 six pack. The end/outboard carbs are off the car. I put a vacuum pump on the inlet hose of each carburetor and pumped up to about 15 - 16 psi. The throttle plates open slightly and then it loses vacuum and they close back shut.
(The vacuum pump and connecting hose are working correctly, it holds vacuum when I plug the end of the hose.)
How far are the throttle plates expected to open when vacuum is applied?
Are the end carbs expected to hold vacuum once vacuum is applied?
