440 Source balancer
Joe Jacalone
9:40 AM
St. Augustine, Florida
My stock balancer was failing, as i found the timing mark had moved quite a bit. I bought a 440 Source balancer, the black one and installed it. Now the crank pulley is rubbing the water pump housing. Anyone else had this problem?
??? If the pulley is rubbing the pump housing then the belts are obviously not lining up ... correct ??
My employee installed it, and he he jumped the gun. It was barely touching. I forgot to add this car has a motor plate, so pump is out further. It's all good now.
