Houle #382
Issue solved
The ones I have used also had a 12 volt keyed feed. If yours is just 3 wires cut the wire from the coil and splice the red going to the coil and yellow to the tachometer.The tach is not in the dash it's a Sun Super tach 2 mounted on the steering column and when I have the Mopar performance distributor in the tach works perfectly
The yellow goes to the tachometer. You cut the wire in two that now goes to the coil from the tachometer. Then splice yellow on the tach side of the wire and red on the coil side of the wire.Where on the tach do you put the yellow wire? I know the red goes to the negative side of the coil and black is ground but there is nowhere to hook it to the tach. The three wires coming out of the tach are attached to a circuit board
Makes no sense. The tachometer should have a keyed 12 volt power source. Just about all Sun tachs are wired like this.I re read you text I have 3 wires out the back of the tach, black is ground red is to the negative side of the coil and green to the lights
So you do have an interface box.Yes it's an old
Yes it's an older Sun tach 2 with only 3 wires. Red to negative black to ground and green to lights
Just google tach wiring. Red does not go to the coil its keyed 12 volts.. Black is ground. Green is to the negative side of the coil. White is lights. Maybe if you hook it up right it might work correctly.No there is no interface box. I got the tach from a buddy and it was just the tach and 3 wires
AND READ WHAT I HAVE SAID MANY TIMES IT SHOULD HAVE 4. You have a screwed up tach then. It defies all logic. Just google sun tach wiring. Use the 3 wires. red 12 volt keyed. Green tach negative, Black ground.MY TACH DOES NOT HAVE 4 WIRES it only has 3 as I have stated many times only 3
OK you win.I have had this tach apart there never was a 4th wire, this tach is a good 40 years old and works perfectly with my Mopar performance distributor
