440 source???
Bens69PlymouthSatellite
10:09 PM
IN.
Hey how are u guys doing? I had a ? about the 440 source is anyone using there deep sump oil pans? harmonic balancers, alternators anything else beside there source heads, what can u comment about the quality of them,just curios because obviously there prices are pretty decent on some things,any info would be helpful
I actually haven't used any of the items you listed, but I have other from 440 source and the quality seems good to me. Their distributors are great for the money.
I know two people that used there rotating ***'y. around 500 cid for 440 block with good results. I have used some of there other stuff with good luck.
didnt know that. when did that happen? I heard about kbre but they arent manufacturing anymore either?
Thanks what about the crankshafts, anyone else beside dantrap know anything about them? the more input the better thanks dantrap and every one else,thats always super helpful!
I used their 440 - 512 stroker kit and it's been running for two years with no problems. I also run their double roller timing chain set and aluminium water pump and housing.
Have the crank checked by a competent machinist. If you can spend a bit more, I recommend a K1 crank.
