318to440charger
- 11:00 PM
- Jul 3, 2025
- Pottstown, Pennsylvania
I am new to this and learning as I go, and boy, it's brutal. I basically look into the engine bay for 5 minutes and then go to the internet for 4 hours, and then back to the car...
I got this 1969 Dodge Charger that originally had a 318 and over the years, and somebody jammed a 440 into it. Fine. I don't know what it's suppposed to look like and when I find stuff online,
nothing is the same as what I have... Fine. The guy who sold it to me says "Just rebuild the carb and she'll run fine." (When he was selling it to me, he could only have it to run for like 2 seconds...) I rebuilt the carb, it took a month. I put the carb on, same problem. Boo. (I'm trying to be brief...) I find that if I hold the key to the right, it stays running... (Bad for coil; I know now...) So, back to the internet.
Dual Ballast Resistor. No videos, not much information except you only need one if 5 pin ECU.... Still learning. I measure this thing and it's one ohm across the top and 5 ohm across the bottom. It APPEARS that the 5 ohm load was wired to the COIL Side and the 1 ohm load was wired to the ECU part... So.... In a caution to the wind moment, I spun the resistor pack upside down and cut of the alignment pins for the connectors
and plugged them back on. Which put the 1 ohm load to the Coil... Car fired right up and ran nicely except that we fiddled around with the timing PRIOR to the resistor issue... (I think the timing is messed up from that.) Anyway, the car sarts and idles now and I am wondering HOW it EVER ran before, with the swapped wiring. you can see in the pic that the wires were just hacked off and added; I believe whoever did that put them to the wrong places. I'm going to continue research and wire tracing but I feel slighted by previous owners if I am correct. Of course, I could be wrong. Here's a pic.
