440 valve lash
67 gtx cov
4:28 AM
spring city pa
i have a 67 440 fresh build did the brakein it has adjustable rockers hydralic lifters thay need adjustment what is the lash setting
There is a spec for that based on a dry lifter but if you do one turn in on a 3/8"-24 thread from zero lash that will work fine.
Most hydraulic lifters like between .020-.060 preload. I have a tendency to run mine on the minimum side so a half turn is what I give em and go for a test spin. A full turn should give you a hair more than .040 which should be good to go like Meep said.
I'm conservative. I like going 1/4 turn down from zero lash. Just personal preference.
