440 water jacket bolt holes on 906 heads
Aron Gleason
11:32 AM
Washington
What is the best sealant to use on the end bolts on a 906 head? And would I be ok, if I remove 1 bolt at a time without having to replace the header gasket?
Main thing is to drain the water first. Threads in the head should be dry before installing bolt or stud for a good seal when using a sealant.
As said, this sealant.
