rustytoolss
I will be replacing My 727 with a 46RH A518 overdrive unit. I will be replacing the cooler lines to 3/8". Would it be OK to run the fluid through the stock radiator cooler , and then into a large external cooler with 3/8" line size. I get that the stock cooler would create a flow restriction. But by then going through a larger external cooler, would that offset the restriction. I would like to keep the stock cooler if possible.
