46RH A518 transmission radiator cooler ?
rustytoolss
8:56 AM
New Franklin, Ohio
I will be replacing My 727 with a 46RH A518 overdrive unit. I will be replacing the cooler lines to 3/8". Would it be OK to run the fluid through the stock radiator cooler , and then into a large external cooler with 3/8" line size. I get that the stock cooler would create a flow restriction. But by then going through a larger external cooler, would that offset the restriction. I would like to keep the stock cooler if possible.
Im not saying it would hurt but, Im not sure it wouldn’t hurt it. Best talk to transmission builder. Maybe the stock cooler could be upsized by radiator shop?
