73rattler
I'm curious,,I have a 472 stoker biuldt out of a 400 block..Indy heads , comp roller cam and prw roller rockers. engine runs great, I have about 180 miles on motor so far..question I have is ,is it suppose to sound like the rockers are loose? my engine biulder has listened to it and says he don't hear anything wrong with it,,and he biulds alot of race motors. but to me they just sound loose..I pulled a vavle cover off and checked them they all seem fine,,I get a little movement on the ones that are closed on the valve. the moter is balance and when it's running it is smooth not jumping or rocking aroundbut it just sounds like the vavle train is loose. I'm was running brad penn 30 weight,but changed over to 20/50. sounds the same so that didn't make a differance. any comments would be appresative.
