5.7L HEMI parts
6PKRTSE
7:54 AM
Motor City
I have a bunch of 05 & up 5.7L HEMI stuff I want to sell.
Most brand new NOS in packages or slightly used (Dyno time only)
-5.7L Hemi fuel injection set ups(5)with throttle bodies, injectors, injector rails, spark plug wire assy's etc $250.00 ea. , Air cleaner box assy (6) $40.00 ea. , Flywheels (7) with hdwe $40.00 ea. , Bell housings (2) $100.00 ea., Complete engine bay wire harnesses (2) $100.00 ea. , idle pulley (5) 15.00 ea., tensioner pulley (5) $15.00 , Exhaust manifolds heat shields (6) $5.00 ea. Emissions tubes $5.00 ea. (2) many bags, boxes of NOS mounting hdwe, clips & fasteners etc.
Truck or car 5.7's?
6PKRTSE will the wire harness work for 02-04 5.7? I found a 02 on Craigslist for $850 with auto trans but its missing the computor and wire harness
I don't know what Chrysler may have change from year to year, but yes they should work. Part # wise they are 03 & up Ram/Durango & are complete from the firewall forward.
Hey there I am looking for some items for my project. Would you be able to email me at s----------------------------l.com. I am not that savvy with the proper way to converse via these forums. I have a 5.7 warranty block, 2007 year with a broken piston at the top ring. Gonna be scrounging for parts to put it together. Would like to hear about some dyno experience you have with any build recipes too. Thanks,
Brian
EDITED BY STAFF. PLEASE SEE THE FORUM RULES BEFORE POSTING AGAIN. NO EMAIL ADDRESSES OR PHONE NUMBERS.
KB67,
PM Sent. Sorry, I have not been on here much at all lately. I have been busy on my E-Body.
Here is a more detailed list of most of everything I have available for a 5.7L HEMI.
-5.7L Hemi fuel injection set ups containing the following components:
(5)with throttle bodies, injectors, injector rails, spark plug wire assy's etc $250.00 ea. , Air cleaner box assy (6) $40.00 ea. , Flywheels (7) with hdwe $40.00 ea. , Complete engine bay wire harnesses (2) $100.00 ea. , idle pulley (5) 15.00 ea., tensioner pulley (5) $15.00 , Exhaust manifolds heat shields (6) $5.00 ea. Emissions tubes $5.00 ea. (2) many bags, boxes of NOS mounting hdwe, clips & fasteners etc.
Most brand new NOS in packages or slightly used (Dyno time only). Some part #’s may be Engineering #’s or production #’s.
6-53032453AB-air filter mounting trays
6-53032405AC-air filter lids
6-53022169AC-air filter breather tubes
6-53032463-air filter element box
1-56051069ADA-engine bay wire harness
6-53032208AG-exhaust manifold heat shields
5-52088656AA-Plug wire looms
5-53032770BA-Air cleaner to intake air boxes
5-53032120AC-Throttle bodies
5-53032777AB-Upper intakes
5-56028502-temp sensor plugs & harnesses
5-53032772AB-Under intake Foam heat shields
5-56051399AA-Injector harnesses
5-53032531AE-Oil filter cap assy’s
5-53022712AB-Fuel rails
5-sets of spark plug wires
7-4736604AA-flexplates with hdwe
2-4711898 bellhousings
5-53032404AA- air filter elements
Bags of 52277576 clamps
Bags of 04268295 rubber boots
Bags of 53032537AA air inlet tube clamps
5-53032645AA idler/tensioner pulleys
Bags of 06506688AA bolts
Bags of 53032540AA air intake clamps
Bags of 06101695 Hex Nuts
Bags of 0527442AA air cleaner hold down clips
Bags of 06507442AA hex bolts
Bags of 06502282 flanged head hex bolts
Bags of 06034247 4” long hex head bolts
5-53032406 air filter lower box to throttle body (says 5.7L Hemi Magnum on it)
