FOR SALE 4 Speed, Sure Grip Rear, Pistol Grip, Superbee Hood, 4 Speed Conversion Kit, G3 Hemi Parts and More!
MoparMike71
4:42 PM
Buffalo, NY
Here’s a bunch of desirable parts I had been accumulating for a build, which I’m no longer going to do so it’s time to sell it all off! I was going to do a modern G3 Hemi swap with a 4-speed conversion on my 1971 Dodge Charger, but ended up selling the car instead to focus on different projects. I’m including some of those G3 Hemi parts at the end here as well in case there may be interest in newer stuff too.
More photos for everything upon request, didn't want to overload the post with hundred of images here. All of these items are things I’ve purchased from others and none of it has been tested while in my ownership. At this time, I would prefer not to separate what I have listed in groupings, but I’m open to it. Willing to entertain reasonable offers on all items.
Located in Buffalo, NY. Preference would be for pickup on the heavier items, but shipping may be possible at the responsibility of the buyer.
1. 8-3/4 E-body rear end housing with axles and new gasket- $300
2. 3.55 Sure Grip, 489 case complete. Light wear on a few gear teeth, but everything spins freely by hand - $850
3. OEM Superbee Hood with insert. Comes with a donor hood if desired. Outer skin has damage and inner structure could be repaired or replaced with donor hood - $1200
4. 4 speed 23 spline transmission. Totally complete, spins freely and came from a running car, specifically a 1969 Superbee - $800
5. Transmission rebuild components and all parts needed to do a 4-speed conversion, all bought new from Brewer’s Performance - $850
6. Complete OEM Pistol grip setup for a bench seat car - $1000
7. Transmission tailshaft - $175
8. Small block aluminum bellhousing - $300
9. 1971 Dodge Charger Speedometer Cluster. Fully operational when removed - $100
10. Fiberglass 1964-67 Hemi hood scoop made by VFN Fiberglass. Painted in a medium bronze, but a section of it has been painted a dark color for some reason. Minor dings and chips, but the fiberglass is solid overall along with all mounting brackets - $250
11. OEM Tuff Steering Wheel. Minor pitting on the metal, but it is the portion that would be covered by the adapter and horn button. Firm grip and no tears. - $200
12. OEM Mopar Steering Wheel - $150
13. 1971-72 OEM Dodge Charger front valance. Light surface rust and some minor rot along the one side where the valance meets the lower fender - $250
14. 1971 Dodge Charger Front and Rear Bumper Guards / Bumperettes - $300 for all
15. 1971-72 Dodge Charger Driver Side Mirror – $50
16. 1971 Dodge Charger Rearview Mirror - $25
17. 1971 Dodge Service Manuals – $150
18. Body Plug Kit (missing 4-6 pieces) - $50
19. 1971 Dodge Charger trunk rubber - $25
20. 1971 Dodge Charger Dash pad - $50
21. 1971 Dodge Charger complete seatbelt set in brown for a bench seat car - SOLD
G3 Hemi Parts
1. Comp Cams Master Cam Kit for G3 Hemi, HRT Stage 2. MK112-303-11. New in box, nothing missing or used. Specifications in photos. This was almost $1600 when purchased so save yourself a few hundred bucks to get the same, brand new thing here. - $1200.
2. Used 6.1 Heads - $1000
3. Used 6.1 Crank - SOLD
4. Used 6.1 intake with throttle body, fuel rail, and fuel injectors - $1200
I'm interested in the Tuff Wheel, could I get pics? Thanks.
