SOLD 500 stroker pistons 440Source #5093 NEW
Outlaw525
8:34 PM
Central Oregon
Feedback: 40 / 0 / 0
Forged, .030 over for 440 block, made by Icon. New in box w/pins and clips, I ended up needing .060. My loss. $599 new. Will sell for $400 plus shipping. Can do Paypal. PM if interested Thanks
From 440Source website:
These pistons are a 4.350" (.030 over) bore flat top piston which will work in a 440 block with 4.15" stroke and 6.76" rod "500CI" stroker combination. All our platinum pistons use 1/16, 1/16, 3/16 ring pack for less frictional loss, and weight saving, full floating .990 pin size. Our table below lists detailed compression ratios:
Bore Size: Dish (-) or Dome (+) CC's Compression Height: Distance Below Deck: 65CC 72CC 75CC 78CC 84CC 86CC 88CC P
Part#: 5093
Bore Size: 4.350 (.030 over)
Dish -4 (FT) CC's
Compression Height: 1.867"
Distance Below Deck: -.018"
Compression ratios:
65CC 13.09, 72CC 12.16, 75CC 11.80, 78CC 11.47, 84CC 10.85, 86CC 10.67, 88CC 10.48
What are the specs on Those? C HEIGHT mainly, and weight. And they are total flat tops, right? Do you know the valve notch volume?
He listed all the specs from 440SOURCE. If there’s something specific your looking for, might be worth a phone call.
Flat top, valve reliefs -4 CC's
Weight: piston 651 grams, w.pin 141 grams
Those are nice pistons, I need some that will work with the 3.75 stroke crankshaft. C Height needs to be about 2.067 for mine.
