FOR SALE 505" mopar mega block wedge motor short block
stage3
8:45 PM
california
Feedback: +5 / =0 / -0
for sale is my just broken in with street miles no racing mega block hemi/wedge motor. maybe 200 miles on fresh build going to just 3 car shows since building it.....Reason for selling !? im replacing this with a 540" hemi.
so,
750HP 505".
started with with a MP 2001 service replacement block listed in that years MP catalog..Crossbolted mains.
bore is at 4.40 (xtra thick cylinders will go an easy 4.50, i had it sonic checked) with a 4.15 Molnar crank and 6.86 molnar rods with 2000 bolts, 504.xx inches.
race tech 2316 flat tops at -.010 deck height. compression with trickflow 270's = 11.3-1
file fit rings set at .025
arp studs added to the mains and line honed in place.
main and rod bearings set at .003 by machine shop.
S&S machine did all the work in san leandro.
new also milodon full cover gear drive all set up with a solid roller CC camshaft, dont like the came pull the front cover Plate off and change cam Not the full cover gear drive. its that easy.
cam is .678 lift and 272-276 @ .050. i run 4 gallons of pump gas with 1 gallon of 110 sunoco.
trickflow 270's new also with 1.6 T&D rockers set up by B3 racing engines.
manton pushrods with isky redzone Bushed EZ rolls just rebuilt new everything also...
the picture's show those coveted cross bolted main bolts !
WILL SEll as a long or shortblock no external accessory's,oil pump.pan, water pump. distributor. carbs. etc. because they will all bolt onto the hemi..
shortblock 12500.00
long block 16000.00 No intake.
modified crossram 2500.00.
motor will be out by end of week. 1st pic shows how far i got today in the removal process.
pick up here or i can palletize it and take it to a shipper of Your choice within 100 miles after its paid for..
motor is in the 95062 area.
i have never has a crossram burn this clean on All cylinders, the carbs being directly over the ports is a Big improvement, Feel the Power !!
there's usually at least 2 overly rich....not here. A&A modified unit.
motor is now out. still in long block form. best of everything..mega blocks dont come along very often especially under 4.50+ bore.
will/can break it down to a shortblock soon if no interest in it as is.
trickflow 270 heads Very low street miles like new just broken in, with 1.6 T&D roller rockers with B3 shims placing the rollers dead center over the valve tips, with manton pushrods and the correct arp head bolts......4500.00 Shipped.
shortblock as newly rebuilt ready to go all specs above 11000.00. needs to be either picked up or plus shipping..nothing better for that Wedge shortblock. HEMI. Any modern aluminum head will overstress that Original 440/400 winter block motor,,,,,Not this 1.
OR 15500.00 complete as shown. picked up or plus shipping.
at this price point i am only breaking even,,,MP blocks have been extinct for decades, and those 440source blocks !? well .............................
broke down the motor today to a shortblock....Hemi Wedge !
10995.00
Best of everything. below what it would cost if u do the mopar/callies route. low (200ish) miles just broken in look at the crosshatch from the hone..
Only high zinc lucas hot rod oil ran in the motor....
updated pic's, cleaned off the 200 street miles...HEMI WEDGE !
Balanced with stock Deck height, 10.725. perfect intake alighment.
i just got a quote for freight from here in california to New york (farthest away for quoting sake),,,983.00 FYI..which i would handle from this end after its paid for.
even If u could find just the block it would cost more than im asking to assemble it.....9990.00 picked up or + shipping.
everythings gone now just sold the crossram, only the shortblock remains.
don't know how old this add is , but am I correct in this block taking hemi and/or wedge heads ? I saw the wedge heads on it , also looks like hemi valley bolt castings (not drilled)...
change pistons / drill stud holes ???????????anything else ??
Depends how it was machined? This one being machined for a wedge bolt pattern of course
from the factory it was to be drilled for Either wedge or hemi heads. not so much after the fact But im sure it can be done, just not by me...Also the drain back boss's for the heads are there but would also need to be drilled...and of course some grinding for the pushrods,,,,,But also i have seen the stage v conversion heads pop up for sale also....
open to offers.....................................
