BryanRad
Built by Kammer and Kammer in Dayton, OH
Sonic checked, assembled, balanced
Block line honed, pressured checked,plate honed
Ohio Crank 4340 4.25” Crank
Ohio Crank 7.100 H Beam Rods
Trick Flow 240 6161T784-CC0
Icon Forged Pistons 10.5:1 Calculated
Total Seal 1/16, 1/16, 3/16 rings
ARP/TF – main, rocker, head, oil panstuds
Firecore distributor – curved
MSD 31233 wires
AR Engineering Valley plate, batwings,timing cover
TFS 61602003 Hydraulic Roller Camshaft
Comp 829 Lifters
Comp double roller timing chain
Smith Bros pushrods
Harland Sharp Rockers CSP-S70015KE
Trick Flow Intake
Holley 82951 950 Carb
Milodon 31580 Pro Touring Oil Pan
Melling Oil Pump
SFI Balancer
Kammer Dyno Results 586 HP, 631 Ft Lb
Dyno time only.
Located Ripley, WV
$15,000
MSD 31233 wires
Comp 829 Lifters
Smith Bros pushrods
Trick Flow Intake
Melling Oil Pump
SFI Balancer
Dyno time only.
Located Ripley, WV
$15,000
